Problem with OPERA
2 replies · 1,873 views · Started 21 January 2004
I got my phone with Opera already installed and it has problems:
- when I select Opera, the home menu is screwed. I have the "services" star then next to it some EPOC code language which is always different;
- when I surf any page the images don't appear anymore, although I configured it to "load images". There is a blank space instead of the images but I can select them and load them separately, and they will appear.
Unfortunately I don't have the original software otherwise I would have reinstalled it. Any other thought on how to fix this?
Is it possible to check if it's installed on the memory card or on the phone? Actually these problems started when I renamed my MMC...
Thanks for the link. I reinstalled the software and it seems to work fine now. I didn't know it's a freeware for Series60.
