help me please.... .sis in inbox
6 replies · 1,678 views · Started 21 January 2004
DEAR 6600 USERS,
I have FExplorer and tried searching for the .sis files that i cant delete in my inbox but can't find them!!!
I have tried installing them agen but they wont open
PLEASE HELP ME !!!!
James
I GOT SIS FSCALLER60 IN MY INBOX ALSO INSTALLED TO PHONE.
will not delete from inbox even if i delete first in app manager.
help...........
-Using any of the file explorers available go to C:\System\Mail
-Select FIND
-insert: *.sis
-then mark all the results and DELETE them.
-then go back to the inbox and delete the messages
did as you said but will not mark using fexplore or delete
also when i delete in inbox it says" general already in use" ,even with it deleted out of manager thanks again....
ok mate sorted,highlight the file then hit the ,c ,button no delete button comes up .then as you said just delete in inbox thanks....
Hi Again....
IT still isnt working....
When i type in *.sis in system on memory card on FExplorer, The screen goes red. It doesnt crash but it goes red....
PLEASE HELP....cause these messages are bugging me...
THANKZ AGAIN
james
case 1 if u r using phone mem to save incoming msgs:
open messaging->settings->other->mem in use-> change to mem card.
it will say to copy the messages to phone chose yes. then it will ask to copy or move the messages chose move, so that msgs will not be on the phone they will be transferred to mem card. then format ur mem card
U R DONE the message will be deleted. now if u want u can switch back to the phone mem if u want
case 2 if u are using mem card to save incoming messages:
its simple just format ur mem card!!
