I have tried to install themes on my Nokia 6600 on the memory card, but they do not show up in the themes menu on the phone.
Is it only possible to install themes in the phone memory??
Themes installation on the memory card???
I have themes installed to the MMC with no problems.
You may already do this but it's worth me saying it. When your in the themes app, with the list of ones installed on the phone, do you flick your joystick to the right to view the ones installed to the MMC?
All I do is double click the theme sis file to start the install, then click ok to UK language, then on the next dialogue box select install to memory card and click ok and it's done.
Ian
This must be what is happening as I was intially stumped when my new theme didnt show up.
P
Thanks for the info. Now I got it
😊 you can install on yor memory card,but when you are in the theme menu you will move the joystic once at the right and you will see the menu theme on the memory card!its so simple..
