Doom for 6600 run or not ?
I try the one of Wildpalm but it's not running and you ?
I downloaded the game but yet to install to try. 😊
If you are installing it on MMC you will need a patch for it to work.
Oh thanks for that info.
Yes I use on the MMc card, so which patch do you speak, where we could find it ???
Thank's
Search the forum,it has been posted quite a few times,but anyway here it is: http://www.allaboutsymbian.com/forum/attachment.php?s=&postid=144121
perfect now it's working well with my 6600 except the sound, I have no sound....so what I could do ?
I think the sound is rather hit and miss. It doesn't work on my phone either even after folling the installation instructions precisely.
Well,sound works on every other Series 60 phone,except the 6600 that is.If you browse the forum you'll see that there are many applications that have problems with outputing sound on the 6600 and work on all other Series 60 devices so untill some fix in a firmware update is developed by Nokia or the developers updated Doom to support sound in the 6600(Very unlikely) you will have no sound.
how much space on the MMC does doom consume?
Arround 1MB.
Does this mean that theres no chance that the sound will work on my 7610 ether?
I saw an updated version at http://www.gamemobile.co.uk/doom.htm
Does anyone know how to change weapons in Doom on the 6600?
it says ABC button and number... but how?
-=kip=-
Press ABC and a number at the same time.
