Adding Favourites
5 replies · 2,070 views · Started 22 January 2004
Hello guys,
Do any of u know how i can add shortcuts of my apps to the GO TO / My FavouriteS?
before i was able to add using taskmanager ... but i tried installing taskmanager ryt now... im having problem with it...errors...
hope somebody can help me out.. thanks!!
bry,
Yea i know, taskman is the best .. but it wont work... can anybody help me with the TASKMAN... there are errors...
Have you tried re-installing the software. Then uninstall it using App Manager. Then install again. Sounds lots of work but maybe can work.
Yep!...
APP MAN is the one 😊 ..
It's a good app and you can add any app to Go To (favorites)...
go for it!
cya!
and also:
Task-manager is from PsiLoc.com
and not the same progy as app-man. from symbianware.com
take App-man. and it will work fine.
