i have noticed that the number 5 key is MUCH softer then the number 9 key, has this happened to anyone else or have i been playing too much pandamonium ??
number 5 button going soft :(
Yep!
But i am guessing that if you get a new keypad all we be as good as new!
isnt the button on the phone itself, i mean there is a button and the top button (on the keypad) simply pushes it
Yea when I meant change keyboard I ment that bouncy back thing. Or am I wrong in thinking it can be replaced?
i dont think it can be replaced mate 😞
The keymat can most definitely be replaced. Just remove the front cover & you'll see that immediately.
They're not for sale in your average supermarket, though.
However, any Nokia authorized service center should have or be able to get them easily.
I think No. 5 is really supposed to be soft to the touch. Mine is like that too even though i rarely play my games.
Cool!
5 & 7 buttons are more softer than th eother buttons. maybe they are not softer but because of the eliptical shape of these buttons to press is more simpler and this can give the feelig that these buttons are softer than others because pressing is simpler 😊
'5' button is the softest in the entire keyboard, followed by '7'. I guess you don't have much of a problem. Changing the rubber pad is needed when u press the button and there is no response.
