need sum advice fellaz wondering if i should go for this
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=2981759708&category=43476
or a 128mb coz they are supposed to work perfectly
thx😃
malice
thx😃
malice
i have heard that kingmax work well but i really can give you nothing more than pure conjecture. Do what you think is best. I think your safest bet is a 128 but if you really want a 256 then go with what you know.
im getting this mmc hopefully sometime next week, i made a post on this so once it comes ill put up a reply if it worked or not
ok ive decided to go for the 256mb, 128mb is too small when you have mass amounts of techno to put on it and a bunch of anime's. ill let u all know if it works when i get it in 6 days........
Not so sure on techno but anime is cool!
why, wot u listen to, pop! jus kiddin😛 probably jus another metal lover..... so many comp freaks are, don understand😕
No not pop!
Are you kidding.
Used to listen to some techo back in the 80s but lost interest I do like some good trance and hardhouse. Got any cool Techo to recommend! Always up for listening to something new!
My "label" GhostDog records 😉 has a couple of Dj's under its umbrella.We prefer drum and bass and techno.If you like I can post a link of some live sets?
yea go for it!
This is the flyer of the party that is going to happen tomorow.
This is the DnB set:http://www.gameover.com.mk/GameOver%20-%20Jan04%20Mix.mp3
http://www.gameover.com.mk/GameOver%20-%20Jan04%20Mix.txt
Techno set will follow.
Will take a while to download!
Ive recently bought a kingmax from Ebay, some dude in hong kong. seemed like a very good deal but the card is very unstable, can just about manage a 3gp or 2 before it seems to get very confused !!
maybe i was unlucky but i reckon ill shop from a reputable dealer in future and spend the extra few quid.
Shadow12,unless you are on ADSL or something,higher,don't even try to download.It will take forever.
DaiMonde,sorry,but i've read more then one problem with higher then 128 MB Kingax MMC's in the forums.
Yes still in the stone age here in greece. All I have is an isdn line and ADSL here will set you back about 800 euros for a basic line for a year.
lesson learnt on the kingmax then, suppose little research is best next time !
oh and get some rock on, cleanes yer soul. well if you have one in the first place of course.
oh dear, must press skip......bit of punk - i want candy....deary me.
Dont forget to leave any reviews etc. in the "tested memory card" thread. So that everyone else knows not to use it.
