biggest MMC
4 replies · 2,107 views · Started 24 January 2004
The topic tells it all.which is the biggest Multimedia Card that is supported by 6600.can it handle with 128mb?
Yes, Nokia says the 6600 is expandable to 128 mb and not higher. But a lot of users have tried 256mb memory and it works. Only not all brands. Just search the forum and you'll find which memory works.
I am using the 512MB MMC from TEC and i am having no problems at all.fast access times and lots of space for everything.the phone recognize 499MB of it which is normal.i totaly recommend it.
