How to Format the P900
2 replies · 2,670 views · Started 25 January 2004
Hey guys, how do you format the P900?
If you want to remove everything except the softwares install when you purchased the phone. Not using the master reset, because the master reset doesnt delete all the software folders installed in the phone. I want to delete all folders, the one that I installed and the ones I uninstalled.
Thanks guys. 😞
In Flip Closed mode, turn the Jog Dial one notch:
UP
DOWN
DOWN
DOWN
(The * symbol is the one on the botton left on your keypad)
This will take you to the hidden service menu, choose option number 3; Service functions to start the format. The process should only take a few seconds.
Btw, this has been mentioned many times before in this forum, so next time, please search.
