somebody can help me to setup again my n-gage?
with a tool that i had installed on my n-gage i selected "restart" then it asked me "reset Phone?" and press yes.... now it doesn't starts up anymore my loved phone!!!! i think the app was called switcher....
help me!! my n-gage has got a reset!!!
i haven' heard anything like that but the pint is you shouldn't poke your fingers whither don't 😃
Try turning phone on and off. Else take it to nokia. Good luck!
Ok lets take it step by step.
Battery fully charged?
If yes press power button until phone switches on!
How can you tell phone is on the lights are on simple.
Now let it boot up give it some time maybe this app caused some minor damage. If it does nothing then you have to take it to nokia there is no two ways about it. They need to flash it and reinstall. Shouldn't cost you a penny. Good luck!
