help me!!!delete operator logo!!!How i can?
4 replies · 3,882 views · Started 25 January 2004
Use any file explorer and goto
C:\system\apps\phone\oplogo
and than delete the .bmp and after the reboot it will automatically get the default operator logo.
hi!..
like Siddharth said...
go with any file manager there:
and delete that file...
is not an option on SeleQ or any file manager, is the same
option that it used to DELETE any file ....
then RE START the phone... and
BINGO.. you get the default OP LOGO ...
cya!
