new SW 3.49.1
5 replies · 1,495 views · Started 26 January 2004
i hope its faster loading times, a faster menu and also hope you can add .midi's to an MMS, the 6230 can apparently do this without any hassles (forgot where i read it though)
Originally posted by GhostDog
You will probably never be allowed to add midi's to MMS because of DMR's forward lock.
Well if i use nokia that is 😉 😃
I used to do it all the time with my GX20 😞
I know one thing it doesent have
Call Divert Menu
Call Waiting Menu and
Network Selection 😊
Couldent tell you what the improvements are as its the only software ive used
Main bugs that irritate me are
If you dont have your contacts number saved in +44 format it wont display thier number on texts.
You seem to only be able to add words to the dictionary from within the message compose :/ most annoying if your using Agile Messenger.
Other than that ive been happpy with the phone.
