Recorder
5 replies · 2,255 views · Started 12 November 2001
When I open the Rec app and go to Tools/Options, I see "Quality" and "Save".
My problem is that when I set "quality" to Normal and press OK, this setting doesn�t stay saved as "normal quality". I see the Options again but I see Compressed quality again. Why?
Does anybody know something about this?
Thanks.
It is curious, I have experienced the same problem too and I don't know what to do User posted image
Un saludo.
I have had the same problem, it is not a permanent fix, but one way to return it to compressed is to delete the ini file for the program.
Zuber
Funny I am running a french9210 and the
menu does the opposite it defaults to normal at each oppening of recorder.
I d Prefer it to be the other way for memory reasons and I suppose that got messed up in the translation
