My nokia 3660 came with 3 language:
English
Indonesia
malaysia
I basically wan to have chinese input on my sms section.
So is there anyway i can install the chinese language pack other than bringing it to the shop and let them upgrade the firmware??
Is there any application that can achieve it via infrared?
you need the chinese text support on the ROM, which means you need to get the right firmware branch.
Enf...
try Q9 chinese input nokia6600, is a shareware program.
i've installed on my 7650 enable me to view and input chinese SMS.
Visit: http://www.q9tech.com/eng/services/download/download.php3
make sure u are download the "english version".
hi xhide,
are you sure Q9 is a shareware? the pdf instruction seems to suggest that you need a registration id to activate it. also, the instruction is not very clear as to which version i should download...i have a nokia6600/english and i would like to be able to write chinese in sms.
would appreciate you input on this.
many thanks!
