uninstalling themes and stuff
6 replies · 3,810 views · Started 27 January 2004
can anyone tell me how i can uninstall some of the the themes i have in my phone? they're great but i find some them somewhat cumberome since i don't use most of them anyway.
go into the themes menu and select the theme, select the options menu and move down to delete.
you can only delete themes you have put on the phone this way as the others come preinstalled
If you go to Themes menu and delete the theme, it is not actually deleted.
Try deleting it this way and then look at the C:\System\Skins or E:\System\Skins folder.
The theme is still there (and its space in the memory of course).
nickg78 wrote:If you go to Themes menu and delete the theme, it is not actually deleted.
hey!!
Icant find the system folder using Nokia Phone Browser, my Themes menu is locked, my phone wont enter the menu... any one have a solution for this?
Brian
