is there a way to change the location of the inbox to the mmc card, so files bigger than 10mb could be transfered to the phone? I would like to transfer big mp3 files to the phone but the inbox is to small.
Yes you can. Go to Messages. Press Options, then Settings, then Other. You will see 'Memory in use'. Change it to Memory card!
sometimes it can be so simple, I always looked for settimgs in my inbox and not in messages. thanks a lot
