I want to get an IR foldaway keyboard for my 6600 and want a decent word processor. Is there any WP software for the 6600?
As the IR port is on the side of the 6600 I need to be able to rotate the screen.
Anything?
/-|R
Anything?
/-|R
Hey this is not as crazy as it might sound to some, one of the main deciding factors for me to buy the 6600 over the P800 was that i found the predictive text input on the nokia faster than using handwriting recognition on the sony.
Yes, the <I>only</I> thing I use my laptop for is writing on trains, planes etc. If I can find a WP that can use foldaway keyboards (ergo I need to be able to rotate the screen to use the IR port), and that preferably has basic formatting; I'm set.
If there isn't one already then, hey! Here's an opening in the market. The 6600 is aimed at buisness users after all...
/-|R
