hi all, i had read (i dont remember where) that it is possible to make the 3650 a webcam with a software?
where can i download if it is free or where can i buy it if necessary?
do you have tested? suggestion?
thx all and sorry for my english 😊
Use bemused.
I don't know how you can use bemused to make the 3650 a webcam but i don't think its doable.Not with bemused that is.
unonessunotutti,you can use the 3650 as a webcam,why don't you search the forums.This has been discussed more then once.
ok! i'll done! i found some interesting posts 😊
thx GhostDog
Sorry my mistake i meant to say remote s60. Mite still be wrng #, ive never tried it before.
Yes,Remote S60 can be used,along with other applications like softcam but i think there is a special webcam application designed by some italian guys.
me, im using RemoteS60 together with illuminositi Software.
It works great!
