i converted a video file using virtual dub making sure abt every settings like audio and all but when i tried converting the avi files to .mo files its giving me errors that audio format not supported but i am sure i made it to 16 bit mono 16khz
what is the prob??
Double check the Audio settings especially if you used the widescreen sideways settings that are included in the MobiClip Turorial.
Rather annoyingly if you use these settings the audio is not set to 16bit and you cannot compress the file after the initial virtua dub conversion.
Just go in and make the change and all will be well afterwards.
