location of phone backup on MMC
4 replies · 3,744 views · Started 28 January 2004
is there anyone who knows the location of the phone backup on the MMC card, is the backup done in one file or a folder of files. I would like to copy the backup to another folder on the MMC card to make a restore possible if a newer backup seems to have errors.
thanks
I use a file tool like Fexplorer to copy the file to another folder on the MMC card. So I can copy it back if a later backup shows any problems.
Originally posted by nickg78
The phone back-up is archived in one file in your MMC:
E:\Backup\backup.arc
You can do it from the Others->Memory menu.
If the file E:\backup\backup.arc exists a Restore option appears in this menu.
I usually transfer the back-up file to my computer using BT or infrared and SeleQ.
