hi. i hav a problem wen switching my ngage on. When i switch it on it says nokia and usualy about 6 seconds later the 'enter pin' appears. but instead now it just flickers and switches off, does anyone know wot i could do to actualy get into the phone because i cant even do a hard reset (becomes it requires going into the phone) thanks
ngage turning on problem
Try to start it on with out mmc and if it starts so format you mmc
no it doesnt even start without the mmc card. ahhh im getting scared, i actualy didnt do anything its randomly not working. any other adivce that i can try ?
if you have time and oportunity you always can bring you deck to Nokia centre..
try checking the contact of your battery and then check it is fully charged otherwise go to nokia.
how do you go to nokia? is there like a centre, because i live in harrow so is there any where close by i can go to ?
i don't know... anyway where you got n-gage so apply there 😉
go to nokia.co.uk, search for the centre section (it won't take too long to find it) and enter your postcode. It'll find the closest one.
http://www.n-gage.com/R1/en/get_ngage/step_1.html <--here you cab find nokia centre specialy for n-gage 😃
try holding the pencil key down when switchin it on. It skips a load of the start up process which cud be part of the problem, otherwise looks like ur only option is the nokia repair centre.
That happened to a friend's 7650 when the boot data became corrupt as a result of malware. It required NSC treatment.
thanks alot evry1. the holding of the edit key doesnt work, but i went to two nokia shops and experienced problems so im jus searching for the right one,i think oxford streets one seems aite, im going to go next week. Another problem Im facing is that my uncle bought it for me as a present from a different country and apparently this will cause problems when reflashing it but im not sure. thanks for the help!
i dont see why!
The only issue that i can see is that it may have different languages loaded in it but default english is always loaded in.
