hard hard format on the n-gage
4 replies · 4,346 views · Started 28 January 2004
how a format the n-gage hard not *#7370# or what is it i need a thing like the green dail button+*+3 that work`s on the 6600 but seems to not work on my n-gage(my problem is that all the time there system error and menu,radio,contants etc. don`t work only to gets call or to make a call)
plz plz help me
*#7370# is a hard reset and it works with the N-Gage.Some missinformed user was spreading false information that it isn't a hard reset.
GhostDog wrote:*#7370# is a hard reset and it works with the N-Gage.Some missinformed user was spreading false information that it isn't a hard reset.
Though I did hear that it is just a soft reset. Something like restoring default settings and just clearing contacts and image/sound/video folders in phone memory. All the previously installed program files on the phone memory are still there.
The hard reset has soething to do with the Call (Green button) * 3, though im not sure how to execute it.
What GhostDog says is correct.
N-Gage does the reformat with *#7370#.
The green/*/3 works only with the 6600 and 7610 (and you use it by first turning the phone off, then pressing the keys down, then powering on the phone while they are pressed down; release keys only after you see on the display that the formatting process has started).
This user seems he needs to take his phone to a local Nokia Authorized repair center and have his N-Gage re-flashed or something like that.
