3gp files
16 replies · 7,034 views · Started 29 January 2004
Hi ppl
Do 3gp files play in real player or do i need a different player for these.
I managed to obtain some and real player says unknown file format.
Cheers
pretty sure they work in real-one supplied with the n gage, its definitely summat very similar to 3gp if its not that ! might not work with the PC version of real-one tho...???
***SABZ - tell me definetly: how I can play 3gp FULLSCREEN on NGAGE? Philips camcoder doesn't work on ngage.
mik_mj,PvPlayer and Mobiclip with its own .mo format.
BTW:RealOne can't play all 3gp/mp4/rm files.Their encoding has to meet specific requirements.
Also check that it has the extension .3gp NOT .3gpp. Some video files are automatically renamed .3gpp
has anyone played with mobiclip ? ive d/loaded the bist n pieces but cant for the life of me convert files. ive even followed the instructions for a change !
is it worth me persisting or stick with built in real palyer ?
Really i found it dead easy.
Well I have converted a few things using mobiclip. A simpsons episode and a few music videos and a few episodes of clone wars. Now the clone wars episodea and simpsons are fine but the music videos the sound quality isnt any good due to the fact that in the current beta format it only supports 16kHz sound. Mobiclip has by far the best quality and the converter is free and its easy to make full screen. Want any info just ask me!
i was trying to convert a dvd id already converted to avi (its mine, nothing dodgy going on here ! move along people..)
thinking about it, im sure it halted on the audio. probably had it on the wrong settings.
Yea you need the setings absolutely as it says in the manual otherwise it does not convert properly. Does anyone want me to post an FAQ on how to make fullscreen mobiclip(its prety simple)?
HEy shadow a guide to converting to mobiclip fullscreen would be great.
thx for all the help
GhostDof do i get the go ahead with the tutorial and make it a sticky at the top of the forum or shall i make it a downloadable txt file?
