try sending a picture, when you reach the part where you are ask how you went to send it BT, I.R., there is also Bluetooth Shared, What is that? Is that liek a shared folder of the phone where in when people bluejack you they can access it right away?
Also have I realized that when we are using the BT headset, when the phone rings and you answer via the phone, the sound isnt transfered to the headset. Im not sure if I noticed this before, but when I do answer from the phone, it still does this "<>" but stops after answering..
The sound should not transfer to BT headset because you obviously have elected for it to go to phone by answering from there. You see the BT connect notifier blink simply because it looks for the primary answer tool first regardless of whether you re-route the call to the phone. That's always been a feature of the Pxxx phones.
It's quite usefull. With my P800 I was never able to send files from my P800 to my laptop. With Bluetooth Shared option you can. I don't know if anyone can access it, I believe you still require to pair first before you can access the shared folder
