Hello to all 9210 rascals !!!
A question concerning Switcher app...
Whit the Switcher app, you have a choice of several staff to close in order to free some memory.
What does the ...EIKSRVBACKDROP... stands for & what does the ...YOU HAVE... stands for ???
When I (ex)terminate the first above option it restarts 9210 !!! The second mentioned option, euuuuh... I do not have a single clue what it stands for... Any help or tips available???
As well, it seems that I am having some error Messages, type... Messaging Watcher, Fax Watcher, Reason Number 6, or even Messaging Watcher, Etel Client Faul, Reason number -28...
Thanks to all.
Filakia
_________________
Sam The �.�.�.� Fan<font size=-1>[ This Message was edited by samthepaokfan on 2001-11-13 1004 ]</font>
You Have is the program that pops up a message when you receive an SMS or FAX or E-mail.
As for the message watcher error message - it seems that the best way to get rid of this message is a format and re-install of all software.
Thanks Patrick.
I quote you -
Now...
If every time I have such kind of error messages I need to Format and re install all apps & soft, I will get very old, with a long beard & be completely impotent !!!
No ??? just jocking !!!
Do you have any clues about those error messages?
Thanks & Filakia from sunny Greece
Hello 9210 users.
I think you get the "message watcher faults" if you use the task-manager to close the telephone-program. Try out yourself Reset your phone. Call your 9210 by another phone -> all ok. Close the telephone-program with the task-manager, call your handy -> "message watcher faults" etc. Press the telefon-button, call your 9210 -> "faults". Restart your 9210, call your 9210 -> all ok.
Willi Herrmann
Aaah, I got a message watcher note. but I thought it was due to the sms assistant i had just downloaded. Is it on the origional s/ware or did I dowload it?
Pondering, Hazy1uk
to fix the 'message watcher fault' try this,
remove batterij
open 9210
during 'start up' press
ctrl+shift+i
the machine will ask to clean up registry,
click yes, you may lose some minor settings, but it fixed my problem with the 'message watcher'
greetz,
mailtoDRe@/\/\eRDRe@/\/\eR</a>
I've had the Message Watcher error message without having task manager or SMS assist. installed, I don't think it's an addon app - just something within the messaging subsystem of the 9210 that sometimes gets confused.
It seems that if do not (ex)terminate the following below tasks or apps with Switcher, than I don't have any more those annoying error messages...
- Eiksrvbackdrop
- Desk
- Telephone
- You have
Greetings & Salutations from Lenina Loxley (this is a perso message to Loony as per the "Classics', you know what I mean)...
Filakia
