Can anyone out there tell me if it's possible to connect the wired headset and bluetooth headset at the same time and listen to the radio throu the bluetooth headset??
Best
Will
Best
Will
No.
Cheers mate 😊
Sendo-x it is then - I was dithering between the two and sendo-x does not have radio, so SX1 was starting to look attractive, but if I can not use it with my headset then there is no point.
Cool.
Will
Wow, is it that important for you to listen to the radio through a bluetooth headset? Wouldn't it drain the batteries quite fast anyway?
Yeah - I have my headset on all the time in my job and when I'm on my bike I currently listen to my mp3's.
The radio option would have been nice 😊
Will
which phone do have willbrady??
The radio option would have been nice 😊Will
Your BT headset works with your radio on your bike and when you're at your job?
eh?
No no no.
I play MP3's currently on my headset.
I would have bought the SX1 if I could play the builtin radio on my BT headset too by pluging in the wired headphone (to act as an antenna) and the BT headset at the same time.
But being as I can not I'll wait for the Sendo-x as the radio is the only advantage on the Sx1 that I can see.
I have a 3650 at the moment..
Will
nokia bluetooth headset device work with sx1?
All Bluetooth headsets should work with any phone that supports Bluetooth headsets .... it's an open standard, which means that all Bluetooth devices should interoperate with each other ... without any problem.
In theory everything should work. But sometimes there are some compatibility issues between BT devices
