I have a problem. need to reformat the 3650 without using *#7370# because the phone refuse to enter the mian and just restart. Anyone knows if 3650 has a function like 6600to reformat without first having to have the phone entered its normal start?
how to reformat the fone?
n2cs wrote:Hi,
i have the same problem with my 6600.... try this press the:
green call key + * key + number 3 key
first remove your memory card, make sure you have 3-4 charge of battery bars,
hold the three keys while youre phone is off turn on your phone but dont let go of the three keys until you see the word formating.. it will take 5min for your phone to format...
hope this will work on your phone.....
No, it can't be done. Only for Symbian Series 60 v. 7 and after. N3650 is Symbian Series 60 v. 6. The only way is to bring it to nearest NSC.
hi dear freeind turn off ur 3650 & turn it on again and keep pressing pen key untill desktop (wallpaper) display ... i'ts easiest way 2 solve your problem bye tc
