everytime i want to install a java game or app(jar.. file) i get a warning during my installation " APPLICATION STOPPED, CHILDINSTALLER"'
the installation does not continue and my application won't work...it's the same thing with every java app or game....
what the fuck is this? 😱
thx fellaz
does it have both .jad & .jar file??? and is it for series 60 phones???
The .jad file is not needed.
RsCa,please use a more civil language in your future posts.
Originally posted by GhostDog
The .jad file is not needed.RsCa,please use a more civil language in your future posts.
i'm nothing with you jad file is not needed....still won't work, and yes the programs are for 6600 phone...
A classic question:
What programs did you install some hours or days before the problem occured?
Did you try restarting your phone?
i had that problem and couldn't get rid of it untill i did a soft reset of the phones factory settings. to do this push *#7370#
that's the annoying thing i always have, childinstaller 😡
he asks me always for a block code after pushing 7370 , but what's the code??? 😞
is there a possibility to retrieve my old block code?
thx
The default lock code for nokia phones are 12345. However *#7370# is a Hard reset and not a soft one😊 so pls. keep the phone on full charge before doing it and also a friendly reminder- You will loose all data after you format the phone.
i remember changing it but don't exactly remember my pass, or it won't accept mine.... 😱
Oh My😱 I think you have to take your Phone to the nearest service centre i guess.......... No other way if u don't know ur pw😛
i know my blocking code but when i put in the 7370 and he asks me for the code, he won't accept....
lazy nokia 😉
Maybe the forum moderators might answer your question.
i have allready found the prob, thx to everyone!!
can close thread now! 😉
RsCa,what blocking code are you talkin about.You need the lock code,if you don't know it,take the phone to a Nokia Service Centre,like machtoners said.
all my java stuff that dont work is on my mmc , so if i format that will i need to format the rest of my phone??? i dont want to do that but my mmc i can handle????
You can format the MMC without formating the phone memory.
