can anyone help me with this please, when i try to backup my nokia 6600 phone using pc suit it gives error" unexpected error ocured , please restart task
please hel me with it
thanks
Nokia 6600 Backup
What connection method are you using. I use bluetooth (Belkin adapter), and everything else works perfectly, but a full backup normally takes me 4 or 5 attempts to get it to run all the way through (I get the same error you describe).
Give it a few attempts and see if you get lucky!
Yeah I had this to had to download all 45megs of pc suite off Nokia website to get it working 😞
Must just be the version on the cd
I can not be sure, but I think your problem may be due to nesting too many directories too deep. I was successfully backing up the phone until I made a directory about 10 layers deep. It gave me the same message.
When I removed the memory card, containing the deeply nested directory, it back up the phone memory just fine.
I had a similar problem when restoring and when I tried the phone again it was corrupted - wouldnt boot up and I had to reformat it - lost EVERYTHING.
PC Suite is sh*te, avoid!
Same thing happened with me, darn.
I'll do it manually this time with all my contacts.
