what is it
2 replies · 1,260 views · Started 01 February 2004
hey there folks.....
i have 3 questions
1: last time i went to carphonewarehouse the guy checked some date of produce or whateva .. how do i check this and how do i know what the date is
2:the back cover is a bit loose i looked at it and tried to make it not so loose....by loose i mean that it wiggles a bit up and down nothing major but its kinda annoying
3:i used pv aouthor evaluation to convert a movie but the movie was widescreen and on the fone it was streched (whats going on???)
anyway
any help would be appreciated
thanx
p.s this is edited...why do all my posts have an envelope which has a black dot on it ----thats on the left just before u click on the thread title
krassen
In pvauthor you can set it to clip a widescreen video down to the screen size in :codec-resize method
Because you posted in them.
