Camera Zoom
9 replies · 3,476 views · Started 01 February 2004
Fantastic! I've finally found a site dedicated to the 6600. I heard that you could download an update to the camera application so that it can go as far as 5x zoom on it? Also is their a program that will allow you to record longer than 9 seconds of video?
Thanks!
Spike.
i would also like to find that software. so far on all the sites i have looked at there is nothing
I think you haven't looked enough.What about: Photographer,Flexicam,CameraFX and probably a few others.Search the online Shop
Photographer has a much bigger zoom but to be honest it is pretty useless because all it does is increase the pixelation. Maybe the picture looks better on a PC but I doubt it somehow.
The only possible advantage, is actually framing the shot as you take it, of course you could just zoom in the pic in a paint program afterward anyway, so.....pretty pointless
Thanks for your reply...I was looking for more of a patch for the existing programs on the 6600 rather than buying new applications?
Is there no such thing?
Spike.
Is there any software tt I can buy to unlock the 10sec on my video camera???
senate:there are a few but not of them are working properly on the 6600.In the future search the forum,your question has been already answered.
loGan:What did you expect,the lense to move towards to object,real optical zoom maybe?The 2x digital zoom on the 6600 camera is the same thing as photographer.
spike5792,no such thing
I didn't expect anything. I was just stating a fact.
