Good Wave Converter
2 replies · 3,310 views · Started 02 February 2004
Hi to all symbian user,
I just wanna ask, what good software to convert mp3 file to wave file, that is compatible to S60 phone and with minimal kilobyte? Its because i do find wave files in the internet, that is good quality and less kilobyte (25 seconds, about less than 300KB)
Thank you very much
--Yuri
If you have Nero (or download it from a FSS like Kazaa), you can use the sub-app Nero Wave Editor to cut, resample and convert your mp3 files to smaller .wav chunks. But if you use PC Suite to send .wav files to your phone it is highly likely that PC Suite will automatically re-size the file to a smaller size before it sends it to your phone (PC Suite converted a 5MB .wav file I was sending to 250kb).
