New here!!
2 replies · 1,207 views · Started 02 February 2004
Hi everyone...
I just buy a new 9210i cell phone... and just discovering the world of symbian....
I need help from U guys, finding some cool freeware stuff, including, multimedia stuff and games...
Hope some one help me...
Another question...
The max size of the MMC that is accept is 128Mb??? And It don�t reconize the SD card???
That�s all
[]s
Diogo
Well, I am also from Brazil, Vitoria - ES.
About software, 500 of them :
- the AllAboutSymbian (AAS) has software sections, including reviews;
- www.my-symbian.com (MS) has a Communicator section with two software lists, the first one from MS and second one from Handango;
There are many freeware and shareware that you can try for some limited time. My suggestions : Acrobat Reader, EBook, Emu48E, FreeCrypt, jZip, SlovoEd, Stacker, Switcher, TomeRaider.
I do not suggest any specific game because I am a OPL game developer... as you can verify on the site
www.PocketIQ.com
it has my Smuggers, as well as PsiCards (it is new indeed) and SmallBase as softwares to Nokia 92xx.
I suggest a 128 MMC card by Internet shopping in Brazil costing around R$250 to R$300. US$=R$2.95.
If you like programming, try OPL so that you can type and compile your own softwares using your Communicator, look at the AAS site for more details.
If you want more hints, contact me by means of
roberto.symbian arroba terra.com.br
where you should replace arroba by @.
Greetings from Vitoria,
Roberto
welcome, my nokia 9210i mmc is 128mb is no problems. You can use up to 256mb.
its website is www.expansys.com
its from UK
they got many things for nokia 9210i.
good luck
Dunko9
