msi dongle/bytestor mem.card
4 replies · 1,963 views · Started 03 February 2004
does anyone have a msi dongle or bytestor memory card and do they work with the n-gage although i can put stuff onto my ngage the pcsuite doesnt seem to recognize that i have a bluetooth adapter,and keeps asking me to select a COM port
although im using usb?i just have to use the dongle software but it wont let me select on the ngage i want to put it?
I'm using a MSI bluetooth dongle.
and yes you'll have to set up a virtual serial port using Bluetooth.
Pc suite will use that serial port to connect over bluetooth with the N-Gage
Using my MSI Bluetooth Dongle:
Right click on the bluetooth icon in the systemtray (next to clock)
Choose quick connect, choose virtual port ...
When the devices find eachother a password will be negotiated and after that you'll be able to start the virtual port using the quick connect.
Now you can have pc suite monitor all the Bluetooth virtual ports.
If this doesn't help you, you'll have to check your manual.
