Operator Logo download
8 replies · 5,461 views · Started 03 February 2004
Hi there,
I wonder wether there are any sites where I can find free color operator logos for the 6600.
Any1?
Harry
infrared or bluetooth. plus you will need a file browser software like FExplorer which has the options to set the image as an operator logo.😊
You need Infrared or Bluetooth to tranfer the file from pc to
phone and than u need FExplorer or Seleq to make the image as
ur operator logo
The program is just what I needed!! Cheers!
Just one problem that I found but I sorted it out for others that may want to use it!
If you have a NORMAL black and white logo installed apart from the Network name, the colour logo will not display!
The easiest way is to reset you operator logo.
I did this using Logomanager and sent it to my phone using the wrong Operator! This wipes off you black and white one.
You can now install the colour logo's!!
Pontelad😃
pontelad wrote:The program is just what I needed!! Cheers!
Pontelad😃
tanku very masht
