I Can't find appropriate option. Is it possible ? I use quite loud sound (Desk Phone Hi). Whet I test it - it's loud, but when the alarm rings - it's so quiet that hardly wakes me up. Help !
How to increase alarm volume ?
The Alarm volume is going up (increasing) the longer the sound-file is.
So if you take a "short" sound it is starting on a low volume again and again - so it is at least not getting loud ..
If you take a "longer" sound-file it will get louder and louder (up to the end of the file) ...
Solution: Take the sound you like and put it ~ 10 times behind each other (as a new sound-fiel), than take this new sound ...
The alarm is very LOUD on my 6600. 😃
The volume increases if you don't wake up straight away.
