undeletable icons
5 replies · 1,996 views · Started 03 February 2004
I have a number of icons on the menu that don't lead to anywhere cos i deleted the applications. now i can't get rid of the icons. please help
Maybe it helps to delete the special/application related "*.sis" files in C:/System/Install or E:/System/Install Files ... but I am not sure about this!!
Try it and post if if worked ...
If you remove apps etc, properly by using file manager the icons will be deleted also.
If you havn't moved it File manager is in the tools folder (in case u didnt know).
You will need to use an app such as FExplorer to delete the icons now my friend.
