I have just bought a nokia handsfree Bluetooth CK-1W , but found out that the 7650 is not compatible with it. Has anyone had the same problem, and is there a way to interact both together. Maybe there is some software that can be downloaded to the 7650 to enable it to work.
Can anyone please help?
Originally posted by necstandards
I have just bought a nokia handsfree Bluetooth CK-1W , but found out that the 7650 is not compatible with it. Has anyone had the same problem, and is there a way to interact both together. Maybe there is some software that can be downloaded to the 7650 to enable it to work.Can anyone please help?
The 7650 does not support bluetooth audio in any way shape or form. So no bluetooth headset will work with it.
