Mobiclip full screen
35 replies · 40,416 views · Started 04 February 2004
Here is the full screen tutorial. Decided to include it in zip file(The document in in doc format) since this would be more effective. If the format is unsuitable please say so and i will post in other formats. Sorry about any typos or anything it was thrown together. Any questions direct them to me and i will try to help.
Attachments: mobicliptut.zip (248 KB)
Hey Shadow,
I've been using PV Author to convert my videos and had used them on my 3650. I just got my N-gage and transferred a movioe to it, but what phone setting am I supposed to change so that the video plays in full screen?
I am unsure since i dont use PVplayer or PVauthor I am sorry. Have a look around the forum I am practically sure it has been mentioned before. If you cant find it go bug GhostDog he is the man to ask!
Darla,Mobiclip and PvPlayer are very different applications.I also use Mobiclip now because of its image and playback quality.This discussion is about Mobilclip.
There are no special settings for the videos to be played in fullscreen(i'm talking about PvAuthor).The feature is on the player side.PvPlayer can stretch any video to fullscreen.
Just in case you are trying to play the videos with RealOne,here is the dissapointement,you can't.
@ Ghostdog
Lol, sorry if I was off topic. I am going to try Mobiclip now. I used #1 DVD to put them on my PC. Can I just take that file and convert it?
Ok I installed the MobiClip to my PC but when I go to install it I get a message saying that I need to install .NET Framework 1.1.4322. It gives me an option to go directly to the site but there are several versions of Framework listed there and I'm not certain which one I need since it doesn't list any of the version numbers.
Download the latest.
Sorry forgot that part. I have already installed since i need it for a lot of applications. Good luck and reqad the manual it makes everything crystal clear.
Ok... I followed the instructions to the T. I did everything and saved the AVI file. But when I go to right click it there is no option to convert to a MO file. I opened the program folder in my C drive to find a MobiClip app of some sort and there is a converter program there, but when i click to open it I get a message saying no input field specified. What am I doing wrong??
It happened to me quite a few times.Start the mobiclip installation again,and select repair.It should fix things.
BTW:There is a new convertor and plater on the market,SmartMovie Series 60.It looks very promissing,you can find the free trial in the online shop.
Ok, after some extensive playing I finally got it converted. I just selected the AVI file, right clicked and chose open with, then browsed for the MobiClip converter. Viola it worked!! However, lol, the movie file is 148mb!! So that brings me to my next question... what size memory card is required?
thats why you should use smartmovie, it ownzz mobiclip in quality and size. The view is also better (landscape)
Size,yes but can SmartMovie play 24 fps videos without skipping?I don't think so.
hi, im new on this forum...
i converted some short clips to .mo (it is safe to assume that i was successful in converting them via mobiclip settings with the tutorial) and when i previewed it on my PC it works flawlessly!
but when i transfer it to my ngage... well lets say all the flaws started to come out... i was watching a some sort of a slideslow! all the time, both the video and audio skips! i dont really have an idea wats the problem....
pls help! thanks!
hey guys..
can onyone explain more clearly? i dont understand... i install the virtualdub but the mobilclip codec isnt appearing in the list? what shud i do to appear mobiclip in the list? shud i have to install mobiclip on the pc? please tell me ...??? you said to get the codec there must have a license? so whats the way to get it?
help me step by step thanks!
can some one plz help me i got Nokia Multimedia Converter 2.0 and ive converted mp3s and videos now how do i watch them on my ngage?
thx
hey!! i just bought a qd......whr can i gt real player for it ??? n whr can i download mobiclip from...as they have removed the free dwnload option from their site :frown:
hey ppl better check this out ..........i found this software that can convert a 40 mb movie file to a 2mb (.3gp) file........and another one that converts mp3 to .rm that can be played in your ngage qd...... for the movie the file i found nokia multi media converter 2.0 and for mp3 the software is sony forge 7.0 i was lucky 2 gt sony from my frnd n the nokia one from the net itself....check it out!!! 😉
well...
i downloaded and installed Mobiclip on my ngage qd.
but when i try to run it....it givez dis error msg---->>>
"Your phone (101fb2b1) is not supported by this player (2.70) "
kindly help 😞
cant wait to watch Troy in full screen 😞(
if you COULD play the movies in full screen will the light keep going OFF and you have to move the keys to ON it 😊
