hello friends ..
i need help from you guys .. can some one tell me how do i load 6600 themes to my phone thru memory card ..
i dont have a bluetooth nor and infra port ..but i have a card reader .. i cant save the themes ne where ... and when i the new themes with other old ones it doesnt load ..HELP
loading themes to my n6600 via card
I think this can be done, I've never tried it though but it's no different to installing from your inbox.
Take out your MMC as normal and create on it a new folder, maybe name it Themes.
Then transfer the .SIS files of the themes you want into it.
Put it back in the phone and bootup.
Now browse through gallery to the 'themes' folder on E: and click the required theme.
Hopefully it should start the install process for you, click ok, select where you want to install it eg. fone or MMC and it should be done.
Then after you can delete the 'theme' folder you created and you have the themes you wanted.
Let us know how it goes.
Ian
No Bro ..it didnt work .. i tried that .. but in gallery it showed No files ..
maybe there would be some other way
Try it with a file explorer application like SeleQ, Fileman etc.
There is a free one made by a guy called Domi, named File Explorer but I can't find the link.
This will allow you to view the files on the phones drives and in this case show up the .sis files.
Then open them and hopefully again the install will start.
Ian
