hey guys i juz wana know how to transfer pictures from my pc to my 3650 without making it smaller..everytime i transfer pictures from my pc to my phone it shows up small..too small for my screen!i tried a lot of alternatives like changing its pixels and stuff but nothing worked..i am using adobe photoshop to change my pictures..pls help!
3650 pictures?
ideal res is 176x144
will
it can handle 640x480 if 176x144 is too small for u but if you're having the same problem with photoshop that i did then its because the pictures are being saved as 480x640, use windows explorer and see if that is the problem
I usually resize them to 174x132. It fits perfectly. I believe this is the perfect ratio to resize. The phone doesn't resize then for real, but only does it so its viewable. If you zoom in the pic will show what it's like 100%
