Stopwatch for N-GAGE
9 replies · 6,337 views · Started 05 February 2004
Anyone have a nice soft stopwatch .sis (not .jar) for N-gage plz???
I try pocketcounter, but it didn't work
thnx
there is a simple stopwatch made byspurce and it is free. i forgot the address but i am attachig the jar file to this reply. but i think nokia should put a stopwatch to n-gage 😊
Attachments: stopwatch.jar (10 KB)
i saw he wants a sis but he said that he is using another app which is not working. this is a working one. i thinkmaybe this will help him....
to Drager: thank u drager, but i had stopwatch.jar, it work on my n-gage, and i look for another soft (more beautiful :cool😊 to replace it
to DireStrife21: but ur soft pocketcounter dont work on my n-gage too, it work normaly on ur phone???
In a way, yes; you can reset the phone to as it was when it left the factory where it was made (clean out everything you might have done to it; remove all contacts, messages, settings, images, sounds, programs, etc., that weren't there originally).
It is done by typing *#7370# on the idle screen (just as if you were calling somebody and typed their number). You will be asked for the lock code (so that this doesn't happen by accident), which, if you haven't changed it, is 12345.
Do this only with a fully charged battery or when the phone is on AC as you don't want to loose power in the middle of this operation (if that happens, the phone has to be taken to a Nokia authorized service center for "reflashing"; they use special equipment to reinstall the phone memory from so called firmware image files).
