can i back up my java games???
2 replies · 1,501 views · Started 06 February 2004
is it possible to back up java games that i have downloaded via wap/gprs onto my pc just in case they screw up on my phone.
if this is possible could someone please tell me how i do it..
thx in advance for all replies.
PC Suite backup (once you remove the midp directories/folders from BackupExclusionList.dat in the PC Suite installation directory).
Memory card reader on PC (if they were installed on the memory card instead of phone memory).
Sending each file one by one to a PC with FExplorer (from http://www.gosymbian.com).
Backup you phone using the Nokia Pc Suite.
Read the filestore.dat.txt file within the backup folder. (c:\nokia\*phonename*\backup)
Re-name the *.dat files which are labled *.jad (in the txt doc) to *.jad and you can then copy the *.jad file to any phone!!
This method will work with any file backed up using Nokia Pc Suite.
