6600 Annoyances
2 replies · 2,051 views · Started 07 February 2004
I love my 6600 but it has a few things that are annoying me..
1. Why can't I set up a profile where calls are auto-answered and automatically played back through the loudspeaker without having to touch the phone. Also in the same profile I would like voice dialling without having to touch the phone.
2. Strange one this but I can't reply to text msgs, if I create a new one it works but if I reply to the same person it doesn't work giving me a error about network settings. Same message centre is set to no.
3. Why does my O2 gprs Internet Access Point not work, a standard gsm IAP works fine.
4. Why are their program files on the memory card, if I change card I wont be able to access them and I dont see any way of moving apps apart from copying them with FExplorer (not sure if this will work)
I had the same problem with SMS messages as I didn't change the beginning prefix. If a number starts 07957 change it to +447957. So basically for all mobile numbers change the '0' to '+44'. This solved the problem for me, not sure whether it will for you. Also it will only work with texts sent to your 6600 AFTER changing the prefix.
As far as apps go, if you haven't got many apps re-install them on the phones memory and store everything else on the MMC, such as movie clips, photos etc. That way the little memory on the phone can be used for applications only. This is what I've done although i'm only running a few apps that didn't already come with the phone... or just buy a big MMC so that you don't have to switch cards!
Search the forums .
O2 internet access point requires you to visit advanced settings and manually put in the ip address for o2.
