Beginner question about customising op logo
4 replies · 2,525 views · Started 07 February 2004
Hi all,
I just read the thread at the bottom about operator logos, and changing them. Can someone plse explain in really basic terms what this means and how it can be done. Firstly it says to use FExplorer to locate op logo folder but in E: under apps i don't have the sub folder called phone. Plse help as I'm intriegued about this whole op logo thing. Thank you.
Wirelessly posted (Nokia6510/1.0 (04.06) UP.Link/5.1.1.3)
Read my guide in the N-gage forum.
I read that one needs to have a bitmap (.bmp) image, dimensions 97x25 or smaller. I made one that is 85x20, and copied it onto my MMC.
Using FExplorer, I browsed to the location of that image (E😊, clicked Options -> File -> Set as operator logo. FExplorer handled creating C:/System/Apps/phone/oplogo/320_307_0.mbm or whatever it was called - I didn't need to worry about that. Then it automatically rebooted, and up came my image!
is there a way to remove operator logo and leave it completely blank?i have a nokia 6600 and it is blocking the full beauty of my theme.thank you :tongue:
geishaslut wrote:is there a way to remove operator logo and leave it completely blank?i have a nokia 6600 and it is blocking the full beauty of my theme.thank you :tongue:
Maybe you can just upload a blank picture, a white .bmp file. 😉
