Just discovered it now. No release notes.
I have not upgraded yet, since I cannot from where I am.
Greets
Andreas
Greets
Andreas
Just updated my phone. The only difference I see is that it seems to load apps faster - at least for World Mate. Will keep you guys posted if I find anything else.
update seems to make phone slower to start with, but after you opened application once it runs smooth afterwards. SE seems to have fixed some bugs, as i do not expirience "unexpected errors" any more { maybe yet 😊 }
Pardon myu ignorance since I envy all of you being able to update your P900's software. But How do you update it anyway? Can anyone guide me thru step by step? And are there any tips that I may lessen the memory usage in the internal memory besides using swicher? Thanks.
Check out this thread for the auto-update;
http://www.allaboutsymbian.com/forum/showthread.php?s=&threadid=18184
As for keeping your memory clear, using some kind of task manager to kill programs you aren't using. SMan and others also have a function to free unused memory. Also, try to keep your Theme to a minimum. The larger and more elaborate the theme (includingh ring-tones) the less running memory you will have available.
