hey is there any software through which we can record the whole call i mean the voice ??
Call Recorder ??
u can try using SPY!
Audio spy allows you to:
Listen to what is happening in the room from another phone
Set up a phone number from which Spy! will be allowed recieve calls, set up the time after which it will pick up the line and
Automatically record phone calls
You can instruct Spy! to automatically record incoming/outgoing or all phone conversations. It is also possible to set up maximum recording time.
30 days trial avialable..
Can't you try using 'recorder' the application that comes already on the phone? Start your conversation, press the menu button and load recorder up.
I dunno if this works - I dunno if it'd record the incoming call's voice, but its worth a try.
The Default Recorder has a time limitation of 1 Min.
Ahsan wrote:hey is there any software through which we can record the whole call i mean the voice ??
You should try also NaturalRecorder, excellent and very "Natural"!! You'll never be surprised by a problem of memory, the soft manages the memory automatically...
You can find it at Handango or at www.naturalwidgets.com 😊
ykalfa wrote:You should try also NaturalRecorder, excellent and very "Natural"!! You'll never be surprised by a problem of memory, the soft manages the memory automatically...You can find it at Handango or at www.naturalwidgets.com 😊
And now, if you go to their web site, you can have it for free if you fill their survey !!!
I did it and I got an activation code! Nice, no? :icon14: :icon14: 😊 😊
Can u send me activation code please.......... 😊
Thanks in advance...
does the NaturalRecorder records call without the beeping sounds?
some softwares make a beeping sound.
i use powerdictaphone and set it to my * key so whenever i make calls i just hold it down and it records. I dont think it makes any beeping sounds but i've had no1 askin if i'm recordin so i guess it dont
somebody said something before about SPY, saying that you can hear what is in another room, from another phone... could you be more specific please (bluetooth ?) thanks
pls sent me 3230 games
pls send me 3230 tones
You have lot of free ones. Go to getjar.com or http://3lib.ukonline.co.uk/nonagss60.htm.
