Best App for file management???
6 replies · 2,313 views · Started 11 February 2004
There's a proven fact that the quality and flexibility of non-Free software is better (Taking the price tag out of the way of course), because when you pay you're expecting to get at least what you're paying for if not more!
So what is the best Symbian 60 file manager on the market (Free or pay doesn't matter)!
I've seen a lot of you's are in favour of FExplorer!
So what's the best???
I have used FExplorer and EfileManager.
They both operate in almost identical fashion. However, I made the switch to Efilemanager because in my experience FExplorer could not handle moving large files (via cut and paste), I had trouble moving any file over 5mb. It cut the file but then on paste simply lost it!
Also, when it did move files for me it was very very slow at doing so. In comparison Efilemanager has solved this for me and now when I send large files over bluetooth to my inbox I can quickly move them to another folder using this application. It is also a little more efficient at finding files and has a handy feature of showing you the current path you are exploring.
Maybe I did not use FExplorer long enough to find that it can also do this, but in my opinion EfileManager is the best.
Adam
HandyFile is good. That's what I use. It's small and self contained, the only thing it DOESN'T do is read hidden directories on the MMC - which is a great shame.
FExplorer,never had any problems with it.There is a feature i miss like the mark all option but i can live with it.
Originally posted by Raikee
well i'm using FExplorer, Efileman and SeleQ.. but SeleQ is the best 4 me!!!
Why?
would be helpful to compare
HI!...
i was using SeleQ v1.65 (was the best) ...
Now in my opinion the BEST it's
Extended File Manager v1.71 from PSILOC ...
more options and faster than SeleQ ...
cya!
