How 2 Use O2 Mailbox On T-mobile Uk 6600
3 replies · 1,869 views · Started 12 February 2004
I HAVE FREE WAP MINUETS ON TMOBILE
O2 SEEM TO HAVE A MAILBOX. MY FRIEND HAS IT SETUP SO HE CAN SEND E-MAILS DIRECTLY FROM HIS PHONE. HE IS ON O2 NETWORK AND USES O2 MAILBOX
IM ON T-MOBILE, CAN I DO THE SAME (USE O2 MAILBOX) SO IT DOESNT COST ANYTHIN WHEN I USE IT AS I WILL BE ACCSESING WAP THRU T-MOBILE
CAN SOME 1 TELL ME IF THIS IS POSSIBLE AND HOW TO DO IT
THX
hahhahahahahaahahahahahahahahahaahahahahahaha 😃 Thats the best idea i have ever heard.
Thank you i needed that :P
go to o2.co.uk and sign up using your mobile number as they dont mind what network you're on and once you've signed up your email is automatically created and then its basically set up and yes it will cost you nothing if your wap is free and get the settings for email etc from your friend
