Hello,
I am trying out Flexicam v. 0.67 and I have some questions regarding this program:
1. IMAGE NUMBERING
When I save the image to my MMC card, the file number will increase. i.e. Image1.jpg, Image2.jpg. However, after I DELETE the files and start taking picture again, the file number begin from the last file that was deleted. For example:
- Take 2 pictures: result is image1.jpg and image2.jpg
- Take another picture: now the filename is image3.jpg, not image1.jpg again.
2. BRIGHT and CONTRAST
I pressed number "3" on the keypad and I see the "Bright and Contrast" icon on the top left of Flexicam, but I can NOT do anything with it. I.e. change brightness. I tried to press left and right, but to no effect. How do I control this?
3. MANUAL
Where can I get the manual for the software? There are certain thing that I don't know what is it for, such as:
- Luminosity
- Equalize
- Normalize, Stretch RGB
Flexicam questions
hi! ...
ok...
i enter to FlexiCam and manipulated for a while the controls..
are really easy ...
The #3 on / off the PREVIEW of the process that is activated...
with the #8 or * ... you turn on / off the menu for all process
options that you can manipulated with the joystick up, down to move over the list and left and right to change values and press over some others to turn on / off like normalize, equalize, etc...
You can go upper the all menu list and press the joystick to turn on / off the background of the menu to see better the changes on the pic behind ...
Remeber that #3 (LIVE PREVIEW) must be activated in order to see the real time changes of the processing that are you manipulating...
#0 to switch between ZOOM or CROP Tool ... and Joystick up and down to zoom in / out or crop vertical, and left and right for Crop horizontal
the other numbers are FX that i know you already saw...
well...
i think that's all...
i don't know any manual for this app... but i think is not really needed anyway if you play for a while 😉
cya!
